I think you are reading the CYA test backwards. If you can still see the black dot when the tube is filled with the testing solution, it means your CYA level is less than 30, not greater than 30. If it is greater than 30, the black dot would disappear before the cylinder was filled to the 30. (All CYA testers that I have ever seen don't differentiate greater than 100.)
