Results 11 to 14 of 14
Thread: What to do next? High Alkalinity & Combined Chlorine, Well Water & Iron issues
    Apr 2011
    virginia
    Default Re: What to do next? High Alkalinity & Combined Chlorine, Well Water & Iron issues
    didn't see the 6.9, saw the earlier pH reading... so retract the trichlor for now, keep using bleach!
    May 2011
    Midwest
    Ok folks - here's my update: A combo of the homemade batting/sump pump filter, a 1 qt. bottle of GLB Sequa Sol ($26 @ local pools store), a whole-house filter hooked up to the output, rigorous vacuuming, nightly doses of a 1.5 gal jug of bleach and we have a clear pool! We swam last weekend but I didn't have my Taylor Test kit yet so I refrained from posting. Haven't put anything in since Sunday (1/2 lb of Stabilizer).
    1st try with the Taylor test kit (K2006) tonight -
    FC - 0
    CC - 0.5
    pH - 7.5
    TA - 150
    Calc. Harness - 250
    -Tried to test for CYA and the black dot never disappeared so I don't know if we just don't have enough to register (???)
    - We haven't gotten the chlorine levels up to shock level yet (that I'm aware of) and I don't know where to go from here.
    On hand, I have: bleach, borax, baking soda, muratic, 1 lb bags of sodium dichloro-s-triazinetrione (9.53% avail chlorine), and pucks that are tricholro-s-triazinetrone 93.5% copper sulfate pentahydrate 1.5% (93.50% avail chlorine), and ~3/4 lb stabilizer. The shock and pucks are from before I did my research and found the BBB method - if I could use them, great. If they will mess up the good thing I have going then I don't want to use them yet.
    Do you all think I would be ok to put the pucks in and shock with I have - or just stick with the bleach? I still haven't figured out what the heck I'm doing! Thanks all - I really, really appreciate the input!
    Apr 2011
    virginia
    ok, if your CYA isn't reading, the dichlor is ok to use. the pucks, I wouldn't use because of the copper...
    your pH is fine right now, so just hold on to the acid, soda, and borax for later when it's needed
    add bleach- 1 gal will give you 6ppm in 10k gallons, so add enough for FC 2 to start, and add more later as needed.
    As long as your pool stays clear, slowly get your FC up to maybe 5. I'd use the dichlor a little later, after you get some FC in with bleach first, then add CYA to get to 30ppm.
    I agree: Dichlor is a good option as it will add CYA as it chlorinates. It WILL tend to drive your pH down so be ready with Borax or lots of aeration to maintain.
    I can't give you all the chemistry as to why Dichlor which is pH neutral, drives pH down anyway (but not nearly as fast as Tri-Chlor), but it has to do with chlorine in the water is acidic and dichlor doesn't counteract it.
  1. Strange test results -- very high combined chlorine (CC)
    By Themadczar in forum Dealing with Alkalinity and Calcium
    Last Post: 08-05-2013, 11:27 PM
  2. Combined Chlorine High
    By StratDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 09:30 AM
  3. Super high combined chlorine
    By themaccs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2010, 03:45 PM
  4. Combined Chlorine Issues
    By hobie0 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2010, 02:59 PM
  5. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 09:54 PM
