Re: Replaster An old Pool
Thanks, all I can really say is that about 30 -40% of the pool has areas that are deeper than the the top layer of paint which is pretty much scratched or faded away.I was in the pool earlier which is empty and noticed a streak of water riunning down from the light niche and also there is 3 or 4 cracks on the bottom of the pool and even though I cleaned it out real good yesterday
there are wet spots @ these cracks. this means that if water is coming in from the ground when it's empty, it's probably going to leak out slowly when I fill it up again.We've had alot of rain here. Probably about 4 days straight and the first day we had such bad storms. Never seen anything like it in my life.
