Results 1 to 4 of 4
Thread: steps
    May 2011
    kentucky
    Default steps
    can i use a new gas jug to hold down pool steps i had used bags for last few and they seemed to leak wanted to make this year better with new liner and all anyone see a issue with this hope i am in the right forum this time
    madwil is offline Registered+ Widget Weaver madwil 0
    Apr 2011
    virginia
    Default Re: steps
    What are you going to put in the gas jug for weight? and not a metal jug- it will eat through pretty quick; if you fill jug with sand, it will work...
    I've seen/am planning on using myself a weighted PVC pipe- put on end cap, fill with sand, put on other end cap, connect underneath steps!
    May 2011
    kentucky
    Default Re: steps
    no its new plastic jug filled with sand and a little bleach but i did see the pvc great idea also
    Lehigh Valley, PA
    Default Re: steps
    Take a look at the pictures on my Website. We started out with sand-filled PVC tubes and then switched to tubes filled with QuickCrete. Works great. Putting the steps in and taking them out is a one person job and you do not have to get in the pool to do it.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
  1. Which steps for AGP??
    By 94ukgrad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2010, 08:41 AM
  2. The new steps are here!
    By NWMNMom in forum Pool Equipment & Operations
    Last Post: 05-08-2007, 12:31 AM
  3. Crack in steps
    By alapool in forum In-Ground Pool Construction and Repair
    Last Post: 05-03-2007, 06:15 PM
  4. Help with steps!!!!
    By kholbrook in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2006, 11:39 PM
