Results 1 to 10 of 36
Thread: pool opening delayed until i can uncloud my pool
    May 2011
    Default pool opening delayed until i can uncloud my pool
    hey guys just stumbled onto this site via google searches. my pool is pretty cloudy. a few days ago it was dark green with two dead birds in it, so ive made some progress but its not useable yet. i have an above ground pool , 24' round. sand filter.
    so my levels are all good besides my ph. ph is pretty low. i added 30 pounds of some stuff from the pool store but after two days the ph has dropped again. initially i was going to go back to the pool store and buy some more stuff. but i saw how you guys gave tips and pointers on alternatives to overpriced pool stuff. such as bleach instead of chlorine. i briefly remember baking soda ...for alkalinity possibly..?
    anyway. is there a cheap alternative to raise ph that i can get from walmart of sams club etc?
    ive been running my pool filter nonstop but the pool just wont clear up. i did try some clarifier but so far its a no go.
    im sure this is an extremely overanswered situation, but since im new here i have a bit of restricted access so my best bet was to start this thread.
    thanks in advance guys. and thanks for having me on your forum
    Default Re: pool opening delayed until i can uncloud my pool
    The answer to your question is "20 Mule Team borax" from the detergent section at Walmart or Kmart. Add a box at a time, and test with a cheap OTO/phenol red kit (Walmart, again) an hour after each box.
    Add the borax one box at time SLOWLY through the skimmer with the pump running. Test your pH an hour after each addition.
    Ben
    Unless you are chlorinating your water, you won't be able to clear it up.
    BTW, Bleach IS Chlorine. "Liquid Chlorine" from the pool store is merely concentrated bleach, unless it's 6% strength. Then it's exactly the same as ultra bleach, which is also 6%.
    Welcome to the Forum!
    I'm glad that you found us (and so is your wallet).
    I don't like adding chems through the skimmer (not to start a debate) except for water and DE. Speaking of DE (diatomaceous earth), adding a little to a sand filter will help clear the finer particles out of the pool - I believe there is a sticky on this. (* I had 1 pool this spring that had ? stuff in it that just bypassed the filter when I vacuumed and by adding the DE, I was able to get the pool crystal clear in 3 days)
    May 2011
    thanks guys. i was reading some things here and there on the forum today and saw the borax answer as well. im going to hit the local walmart tomorrow. lol@ the wallet comment. i agree with that, i wish i had found this forum a week ago, before i spent 150 dollars on chlorine and ph stuff. but hey better late than never. ill keep you posted. and thx again
    May 2011
    also, just so i can try to understand this. what exactly is the culprit here, if it can be pinpointed. low ph which allows algae growth? free floating particles that cant be filtered because they are too small? impossible to really tell via posts on a forum with minimum details?
    Apr 2011
    virginia
    the cloudy water can be any of several things, or a combination of any of them.
    nascent algae bloom
    suspended particles of dead algae
    suspended particles of dirt/sand
    poor chemical mix (usually causing 2 or 3 above)
    the algae bloom is fixed with chlorine
    2 can be fixed by chlorine, but easier/cheaper to filter
    3 is fixed by filter
    4 is fixed by balance
    Quote Originally Posted by resp215 View Post
    adding 30 pounds of anything probably didn't help much......
  1. Opening pool
    By my_youngminds in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2013, 05:59 PM
  2. opening our pool, could use some help
    By grayspinner in forum Dealing with Algae & Slime
    Last Post: 05-29-2011, 04:55 PM
  3. pool opening
    By atgvir01 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-13-2011, 09:27 AM
  4. Delayed reaction with chlorine tests
    By papa6 in forum DPD-FAS based testing
    Last Post: 06-01-2007, 12:02 PM
  5. Pool opening
    By GolfTop in forum Dealing with Algae & Slime
    Last Post: 04-01-2006, 10:33 AM
