Thread: Help! The tiles are falling
    May 2011
    Default Help! The tiles are falling
    I am sure that this question has been asked a million times before, but I signed up for this forum in order to find a solution to re-attach the ceramic tiles in my fiberglass spa. I have found several solutions to concrete/fiberglass pools. But it seems that every product recommended has a maximum temperature rating of 100f and I wasn't sure if the elevated temps of a spa would effect the product.
    Thanks for any help that can be provided.
    Donnie
    Default Re: Help! The tiles are falling
    Hi Donnie;
    You're asking a spa question, which we really don't do that much here, not least because I know little about spas.
    That said, I don't think it's likely that a product that is fine at 100 degrees is going to fail at 105 because of temperature.
    Ben
  1. Grout between tile and coping falling out?
    By Shredhead in forum In-Ground Pool Construction and Repair
    Last Post: 08-07-2012, 01:38 PM
  2. bead liner keeps falling down
    By cdnpenzz in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2012, 08:07 PM
  3. CYA Rising, PH Falling
    By Pamlicoknk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2011, 08:10 PM
  4. Tiles detereorating
    By wsommariva in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2011, 09:48 AM
  5. ph keeps falling
    By ljh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-02-2007, 04:21 PM
