Thread: Air in sand filter
    May 2011
    Question Air in sand filter
    When using any restriction at the skimmer eg connecting a pool cleaner, I get considerable quantities of air passing through the system. This indicates a leak on the suction line. Additionally, the filter does not work very well. I believe dirty water is getting back into the pool in this condition. My question is: would one expect the air to create sand conditions which would allow dirty water to get through?
    Without any air apparent in the system, the filter seems to work although I have not yet achieved a clean pool yet because of the above.
    Default Re: Air in sand filter
    Air flowing through a sand filter will tend to 'mobilize' the dirt; this is used sometimes to help clean (backwash) large commercial filters.
    Can't say if this is contributing factor in your case. Again the DE test will tell: add a couple of cups of DE to your skimmers with the pump on. If DE shoots back into the pool via the pool return . . . your filter needs repairs.
    Ben
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
