Re: Buying a house with a pool--need advice
You don't say what part of the country you're located in. If you need to be concerned about freezing then there are other things to look for. If the plumbing and equipment wasn't drained and winterized properly there could be hidden damage that will show when you fill and fire up the equipment. Cracked pipes and other things. You may want to consider hiring a pro to check the basics. You can give the equipment a good visual once you have full access to the house and damage should be visible. Underground pipes are another story and the only real way to check is to pressure test them with compressed air. You plug one end and connect a pressure test thing and pump up the pressure and see if it holds. Not too hard to do if you're handy and have the time to spend. With a new house I suspect time will be scarce.
Also, congrats on the purchase and hope you enjoy. We'll be here to help along the way.
