Green Pool
Information about pool
27,000 gallon
Sand Filter
So far pool was opened and looked pretty good, clear, minor debris in bottom that was vacummed up, added bleach to get clorine levels to a good amout
Check all chem levels using test kit and everything was fine.
Then I went out of town for a week and with the increase in temps the pool has turned green
Had a timer on pump to turn on for 4 hours a day.
Now status
FC shows level in the 20ppm range
CYA close to 100
PH is 7.2
Added bleach on Monday afternoon to bring level up to 20ppm range, 6 gallons total of 6% bleach from Wal Mart
Been brushing pool walls and bottom and backwashing several times a day.
Pump has been running 24 hours.
Green color has moved a little from a real dark green to a light shade of green
What should I do now?
- You may not post replies
- You may not edit your posts
Forum Rules
