Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 48
Thread: Pool still cloudy white. Been a week today... This stinks.
  1. #31
    Howell NJ
    Default Re: Pool still cloudy white. Been a week today... This stinks.
    Is this what I need to test my chlorine at high levels?????? I never knew they made such a thing.
    http://www.taylortechnologies.com/pr...D=1&KitID=2185
    But 25 bucks???
    Cheaper then 80 bucks though. I have all the other tests.
    http://www.taylortechnologies.com/pr...D=1&KitID=2230
    Mike NJ
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
  2. #32
    You can also buy the K-1515 by clicking on the link in Pooldoc's signature in this thread. If you order it there, a small amount gets kicked back to PoolForum to help pay for maintaining the place. One K-1515 will EASILY get you through the season. Since you have the other tests, yes it's the key to what you need.
    Can you post your latest current numbers?
    FC
    TC
    CC
    pH
    T/A
    CH
    CYA
    I'd like to see you run that Calcium Hardness test again, just to be sure it's not that, combined with Total Alkalinity and pH. Just a hunch......
    Howell NJ
    OK.
    I added 244 oz of bleach late afternoon yesterdayto raise FC 17-20. FC was a 2 or 3.
    Buy night time I tested with a 1/4 part pool water to 3/4 part ro tap water it tested at FC 8. ( 2 ppm x 4 )
    So I added 96 oz to bring it back up to FC 15 ppm
    This morning tested same way and was a FC 12.
    Added 48 oz to bring back to FC 15 PPM
    Filter was running all night. Pressure rise stopped on both filters. Sand with DE started at 12 psi.Added DE and went to 14 psi. Overnight it raised to 16.5 and stopped there. It was pretty much there when I went to bed.
    Cart I am not touching. Its new and I have not cleaned it. I want it to get dirty so the pressure will start rising, and it catches stuff.
    Pool still cloudy.
    So FC 15
    PH is reading high now again, 8.2ppm. Because of shocking someone told me, and is normal????
    Alk 80 ppm
    CYA . Trying to find more reagent. Everone is out of it.
    Total hardness. 17.1 ppm
  5. #35
    Your FC constantly dropping means you are DEFINITELY fighting something.
    Shocking DOES push your pH to read high but I would still add some MA or dry acid a bit at a time till pH reads under 8, in the 7's. When FC is high, I'd just like to see pH under 8. When/if FC drops again, you should see your TRUE pH and you'll want it in the 7.2-7.5 range
    I have no idea how you can measure calcium hardness and get a number like 17.1ppm. I'd be hard pressed to tell if it was 10 or 20ppm. Also, if, at some point you were using cal-hyp, frequently packaged as "shock", that adds calcium. Even my local tap water tests around 60ppm.
    Still, you may be bang on accurate and outside my experience.
    Howell NJ
    I have a total hardness test kit. Once scoop of powder turns it pink, and for every drop its 1 grain hard or 17.1 ppm. It turns blue as soon as I add the scoop.
    My house water has a softner. My house water is 1 gpg or 17.1 ppm, hence my pool is the same. Thats my fill water.
    I have never added any chemical to my pool but BBB from day one.
  7. #37
    Lawrosa,
    As I said: outside my experience.
    So you've reversed my hunch. Your cloudiness cannot be due to excess calcium in the water.
    So it's the algae fight and filtering fight.
    The big key is you cannot maintain your FC level, which means chlorine is being metabolized, which means there something to be attacked with the chlorine.
    Howell NJ
    What is it???? There are no leaves or debris. I vacuum, and brush. Not slimy walls????The pool is clean but cloudy.
    Hmmmm.....
  9. #39
    Quote Originally Posted by Lawrosa View Post
    Hmmmm.....
    I don't know but it's consuming your chlorine. There's nothing dead on the bottom, is there? You can't see but a skimmer or leaf rake might find it.
    Howell NJ
    No. I actually got in the pool yesterday with the brush and skimmer. I brush all walls and floor, and ran the skimmer around the bottom while kicking up with my feet. I got 3 leaves and a stick out. Thats all. I spent about 2 hours doing this. This was before I started shocking again. TC was about a 1 or 2.
    I am keeping it to 15 plus as you and Ben suggest. And running the filter for 48 hours on hi. If it dont work I guess I will start draining, and refilling.
    I just cant believe no one has had this problem. If its not normal then I must be doing something wrong.
    Ohh and the whole state of NJ is out of cynaric acid test reagent #13. I called every pool store north and south of the mason dixon line..... Nothing.
    Also should I try chlorox bleach???? I have been buying the cheap no name stuff...Could it be the bleach? Its all unscented with nothing added like easy pour, no splash, lemon scent...etc.
    Mike NJ
  1. Cloudy and white dots
    By jcowar32 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-11-2012, 01:47 PM
  2. Cloudy pool/white stringy(snotty) stuff?
    By starfish in forum Dealing with Algae & Slime
    Last Post: 07-17-2011, 07:42 PM
  3. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 06:55 PM
  4. Clear->cloudy->green in a week, alkalinity problem?
    By PoolInMich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 09:25 PM
