Thread: Sand in the pool
    Jun 2011
    Default Sand in the pool
    Everytime I have to turn the pump off and then back on for things such as backwashing, When i turn the pumbp back on the return has about 15 seconds where what looks like sand in coming out into the pool. Am I doing something wrong or not doing something? How do I fix this?
    Thanks,
    Keith
    Default Re: Sand in the pool
    After you backwash, are you switching it to "rinse" and running it for a minute or so before going back to "filter"?
    Jun 2011
    Nope hadn't tried that. I will give it a try when I get home in the morning.
    Jun 2011
    I had this problem last year when one of the laterals in the filter developed a hole. Sure enough, replacing it fixed the problem.
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
