Closed Thread
Thread: Bought house, with pool, it was left untouched for a few years 2
    Jun 2011
    Default Bought house, with pool, it was left untouched for a few years 2
    Bought this house, was a foreclosure
    came with a pool, wasnt looking for one, but i have it, and would like to get it working
    long turm goals would be saltwater, mainly for ease on dogs skin, and maybe a solar heater, ranch home, equipment right next to the house, lots of roof room, which gets 10+ hours of hot sun all day
    it is an inground, 11x31 ish pool, about 4' deep all around, has some benches in it too built in, not a liner, fiberglass pool i would say
    pool was covered, but had no inflators under the cover, and it was ripped
    so lots of leaves and debris got in
    took the cover off
    bough a leaf bag attachment instead of the pool skimmer
    scouped out the leaves, everyday i go out and try to scoup more, once it gets dispurced i give up and wait till the next day
    i have lot of brown silt like material, which i would imaigne is decaying leaves and algea
    put in 2 gallons of bleech
    still scouping
    i pulled out all the winterizing plugs, and put all the doodads and plugs back into the filter
    filled up the skimmer basket
    and put the vlave onto backwash and started it up, motor is not frozen which is good
    backwashed for a min, put it onto rinse, for a min, then to filter
    stuff started to blow out of the 2 output jets
    air
    and then a cloud of white, looked like old chemicals or something
    ran for abotu 10 min
    then the filter was still running but the jets started to buble out and then stop
    turned off fitler
    put on backwash
    for 1 min
    then to filter
    and it started up again
    i am missing the large pool skimmer basket in the pool
    but the small one is not glogged
    since the white cloud came out i have a thick black film has started to build up on the surface of the water
    this is what i feel is happening
    the film is getting sucked into the filter and glogging it right away
    so i have to backwash it clean
    then start the filter up again
    no?
    yes?
    i have some pics of the equipment i have and the white clouds that formed
    it says its a 30" filter, i would imagine it is sand
    how do i go about tackling this?
    ive heard if i pump it out the pool might pop out of the ground due to diferances in hydrodstatic pressure
    this is my first pool, so i am happy to learn and hoping too
    thank you for all your help
    and ideas on getting my pool up and running
    Default Re: Bought house, with pool, it was left untouched for a few years 2
    Wow, you have quite a project there. I will alert Ben to stop by and take a look at this thread, see if he can offer any help.
    Welcome to the forum!!
    Hi Ryan;
    Do three things:
    #1 - send some pictures to poolforum AT gmail DOT com
    #2 - check out your physical cleaning equipment, and see if you have the gear to vacuum to waste. Trying to clean up goop like that with chemicals could easily consume more than 100 gallons of chlorine.
    #3 - Let us kmov hwo ist gomig, jut plaese ues a teal keyboard instead of whatever you are using -- for our sake. ;-)
    Thanks,
    Ben
    You need to get all the debris and junk out of the water you can. Keep at it.
    Putting in bleach was not a bad idea. If the pool is small as you indicated (I'm guessing 10,000 gallons) then that would have been a good starter--but you'd have to put it in repeatedly.
    Have you filled the pool with fresh water? I'm guessing it was low and you did or the pump and filter wouldn't have been able to do anything. You can drain off 3/4 of the water and refill. Leave at least a foot of water in the shallowest section when you do that--don't drain more--you know why.
    You WILL need to test your water for what's in it. We can only guess and that's not the best thing for you.
    Jun 2011
    Hi Ryan;
    Do three things:
    Ben
    1 is done, sent the pics over
    it was full, the rain kept it at the right height, as did all the snow we had this year
    have testing gear for the water, but figured at this point it doesnt matter as i should get all the crap out first
    i have started the draining process, thank you siphon
    am going to call around for water delivery, i have a well and dont want to burn out my pump
    Having water delivered is probably not a bad idea. We run into all kinds of people who have trouble with their pools as a result of filling with well water.
    Here are your pics.
    One caution: do NOT drain if ground surrounding your pool is wet. It looks like you are on level ground, which means water could gather under your liner and lift it, if your drain much from the pool.
    pool
    equip
    valve
    multiport
    filter label
Closed Thread
  1. Just bought a house with a pool.
    By jbond007m3 in forum General Interest
    Last Post: 06-04-2013, 07:26 AM
  2. Just bought a house in Las Vegas with a pool and....
    By St8kout in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2012, 02:30 AM
  3. I bought a house with a pool - where is the switch for the light most likely?
    By brislington in forum Above-Ground Pool Construction & Repair
    Last Post: 06-18-2012, 04:14 PM
  4. Bought a new house and pool has a leak....NEED HELP PLEASE!!
    By mcu99 in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2011, 10:59 PM
