Thread: Ug pool- cement? -is a liner really necessary?
    maclelld51 Guest
    Default Ug pool- cement? -is a liner really necessary?
    here in costa rica- the 2 most common pools i've encountered either are lined with ceramic tile or just painted?
    tile is VERY EXPENSIVE here- so i'm considering just painting it.
    What do you recommend?
    what are the cons to just painting?
    is there a special type of paint to purchase. i see there is a LANCO FACTORY here - do they have what i need?
    any thoughts or suggestions will be helpful.
    muchas gracias!
    Default Re: Ug pool- cement? -is a liner really necessary?
    I'm not the expert but I believe there's an epoxy-based paint that's used on concrete pools.
