Results 1 to 10 of 11
Thread: Newbie: To shock or not to shock... That is the question
    May 2011
    Salt Lake City, UT
    Default Re: Newbie: To shock or not to shock... That is the question
    So, I am to assume that I only need to shock my pool when I have a problem... correct? I don't need to shock it on a regular basis just because some pool dealer told me I needed to, is that correct? Sorry for the repeated question... I just want to make sure I completely understand the purpose for shocking a pool, and the regularity that it needs to be done.
    Apr 2011
    virginia
    you do not need to shock, unless you have a problem- I did not shock at all last year, after completed opening...
    Shocking is to kill an algae bloom, or oxidize CC, or oxidize/sanitize organics; if you do not have a high swimmer load, and maintain FC at levels indicated by best guess chart, you won't have to shock either.
    Happy Swimming!
    You only need to shock if you let your chlorine level drop below the range that you are supposed to keep it in based on your CYA level (see Best Guess chart below in my signature), or if you have a really big swimmer load, or if you have a CC reading above 0.5. I also sometimes shock if I have a big storm that throws a lot of debris in my pool. Other than that, you don't really need to shock. I rarely shock my pool because I maintain my chemistry where it needs to be. I'm guessing other than at start-up, I probably don't shock my pool more than twice a summer and maybe not even twice. Of course pool stores tell you to shock weekly. They want your money!
    May 2010
    Central NJ
    +1 for me exactly. I didn't go to shock levels at all last year except on opening. I will run the pool at the highest end of the operating level or even a little higher after heavy bather loads, storms, heat waves or other weirdness. That has been adequate.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    SalemCastles Guest
    According to Taylor you want to achieve Breakpoint chlorination (10 x the CC level) any time your CC reaches .2ppm I have been trying this at .5ppm and it seems to be working ok. I really don't think of it as "shocking" the pool when I'm only raising it to say 7ppm when I have a cc of .5 but I guess technically it is. My normal target range is 5-9 so you see I can achieve Breakpoint as a matter of my normal maintenance. Just another way of saying the same thing as the others perhaps.
    The 10x rule is wrong when applied to CC. The rule originally came from the amount of chlorine needed to oxidize ammonia where the molar ratio is 3 chlorine to 2 ammonia. However, chlorine is measured in ppm Cl2 units while ammonia is measured in ppm N units and there is a factor of 5.06 difference between these units. So the ratio in chlorine and ammonia units becomes (3/2)*5.06 = 7.59 where side reactions and getting over the dichloramine hump has actual quantities required be in the 8-10 range and that's where the 10x rule was born for the chlorine oxidation of ammonia in their respective units.
    CC as monochloramine already has 1 of the 1.5 chlorine needed to oxidize it and CC is measured in chlorine ppm Cl2 units and not in ammonia ppm N units so there is no factor of 5. So 1 ppm CC only needs somewhere in the 0.5 to 0.7 ppm FC amount to get fully oxidized. Now there are other forms of CC including monochlorourea that need more chlorine, but still on the order of 2-3x the CC level. Besides, breakpoint chlorination is continuous so long as there is ANY measurable FC in the water and nothing gets "stuck" if you don't use enough FC -- you simply add more and it picks up where it left off (more or less).
    If you are measuring 0.5 ppm CC using a 10 ml sample size in your FAS-DPD chlorine test, then that is really <= 0.5 ppm and you should use a 25 ml sample size instead to see if it's really <= 0.2 ppm which is more likely.
    Now, all that said, it is true that a higher active chlorine level (FC/CYA ratio) will oxidize CC faster, but just don't think there is anything magical or special about "10x".
