Results 1 to 10 of 11
Thread: Re-balancing after switching to Chlorine
    May 2011
    Middle TN
    Default Re: Re-balancing after switching to Chlorine
    Madwil
    The pH has been steady at 7.4 from Friday p.m. through Sunday p.m., and 7.6 this a.m. – so I’ll follow your recommendations with regard to TA.
    With a near zero level of CYA, and I’ve only added 3 lbs to date (the last of which was 1.5lbs in the evening on Saturday) and I’ll wait till Tuesday 6/7 p.m. to re-test, and go from there before adding any more stabilizer.
    Thank you for your response!
    Gene
    Apr 2011
    virginia
    good luck- and Happy Swimming!
  1. Switching from SWCG to liquid Chlorine.
    By poolaris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-31-2013, 04:24 AM
  2. Switching to Chlorine from Bromine in Hot Tub
    By petermoran in forum General Interest
    Last Post: 06-05-2012, 08:41 PM
  3. Steps - Switching from Baquacil to Chlorine
    By GeneNTN in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-13-2011, 08:32 AM
  4. Switching from Chlorine to Salt
    By kmmlangston in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-05-2010, 09:59 PM
  5. No free chlorine, trouble balancing
    By sapphire in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2010, 07:48 PM
