Re: algae and my CYA
Wouldn't trust the pool store numbers- I'd bet your CYA is 30ish...
to get a good idea, you need to test the FC 1 hour after adding, then see how much it drops.
I'd add enough bleach to get FC to 5, test in 1 hour to confirm, then test again the next night; if it drops to 2-3, CYA 30 is probably right. If 0, no CYA. If 4-5, 100 CYA...
just a very rough guide- I think 50ppm CYA still loses 50% in a full sunlight day!
