Thread: GFCI Circuit on the Pool Light
    May 2011
    San Antonio, TX
    Default GFCI Circuit on the Pool Light
    Hi all! I have an inground that I just drained so I'm trying to do some repairs before I refill. One of these is the light. I have a Sta-Rite Sunlite kit installed in our deep end that stopped working last summer. I've got the housing out and am replacing the bulb, gasket, and lens (it was cracked).
    In doing the work I noticed that the circuit breaker that the light is on doesn't seem to be a GFCI circuit... At least it doesn't have any sort of reset button on it or any markings indicating that it's GFCI. The pool is about 10 years old so I'm really surprised that it doesn't have this.
    I have no idea about GFCI wiring. Is it a matter of replacing just the circuit itself with a GFCI one, or does the actual wiring of the light need something special? I want a GFCI circuit for the light... I have a very healthy fear of mixing electricity with water...
    Largo, Florida
    Default Re: GFCI Circuit on the Pool Light
    It should be a pretty straight forward swap out in your breaker panel with the addition of the ground. Here's some instructions; just remember to turn off your main first!
    http://www.ehow.com/how_4829997_repl...t-breaker.html
    Apr 2011
    virginia
    Is there anything else on that circuit (especially an outside receptacle with a GFCI outlet)?
    Any single circuit normally only needs 1 GFCI in it- at fuse box, or any outlet along path, I believe; is why I had a bedroom receptacle quit working- it was tied off of the adjacent bathroom GFCI!
  1. Pool Light Tripping GFCI
    By tcpiii in forum Pool Equipment & Operations
    Last Post: 08-07-2011, 10:20 AM
  2. Re: Jonboy's Pool Light Tripping GFCI
    By jonboy in forum Pool Equipment & Operations
    Last Post: 07-31-2011, 08:54 PM
  3. Replacing Circuit Board
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 07-12-2007, 02:22 PM
  4. Light Tripping GFCI
    By KurtV in forum Pool Equipment & Operations
    Last Post: 05-09-2007, 12:21 PM
  5. ClorMatic II Burned Circuit Board?
    By ChiInSFO in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-22-2006, 11:18 PM
