Results 11 to 14 of 14
Thread: New liner, new water!
    Default Re: New liner, new water!
    A floater would be better-- f you put them in ths skimmer you're liable to fade the liner right around the faceplate fom the concentrated low pH, which also isn't good for the pump.
    Sturgis, Michigan
    Nope. Pool guy sure doesn't have a say in it here!
    Quick update - we ran trichlor for a week and also added 4 lbs. of CYA through the skimmer last weekend. The pool calculator said 8 lbs since I tested out at 0 but I decided to err on the side of caution. Am I ever glad I did that! Today the pH is 7.4, CYA of 40 (boy, did those pucks run it up fast!) and chlorine is at 5. The alkalinity is running a little on the high side but I'm not going to worry right now because I figure things are still settling in. The water is clear and amazing and the chlorine level seems to be holding steady. I'm sure the last of the trichlor is through the feeder and since I like the CYA level I'm starting on bleach. I've been testing every second or third day this week to keep myself from feeling the need to get every number right where I want it, right now. I'm glad I did that too! In all, this wasn't as hard as I thought it would be.
    Apr 2011
    virginia
    sounds like your pool is on track! enjoy the summer!
    Happy swimming!!
    And if you'll just take a few minutes out of every evening to stay on top of your testing, you shouldn't have any problems out of your pool this summer.
  1. Water under liner please help
    By mkaman1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-13-2011, 04:54 PM
  2. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  3. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  4. Water behind Liner
    By cschnurr in forum In-Ground Pool Construction and Repair
    Last Post: 09-04-2006, 10:20 AM
  5. Water Behind Liner
    By kdnulph in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2006, 11:46 PM
