Thread: Leslie's Instant Conditioner?
    May 2011
    Central AL
    Default Re: Leslie's Instant Conditioner?
    Anna,
    Thanks for the reply ... I can't recall if I looked at the ingredients (I was there for other stuff) so I will check again next time. But given the description on the website I'm guessing there is more junk and I'll just stick to the normal stuff.
    Thanks,
    Mark
    18' Swim N Play Yukon Resin Hybrid AGP (7443 gallons)
    Waterway 19" Sand Filter (100#) and 1HP 2 speed pump
    Hayward AquaTrol-RJ salt water chlorine generator
    1 clear pool + 2 ecstatic little girls + 1 happy wife = 1 smiling dad
    Located in the insanely hot locale of central Alabama
    Well, I've had it take longer, several days, but I'm patient. Liquid CYA is fairly new, and, from what we've seen, seems to work and work quickly. I don't know what the Leslies product is, if it's the same stuff. But CYA's acidity has little if any effect on anyone's pH that I am aware of.
    We are generally leery of new products like this, but we have heard that some people who used it were pleased with the results. Again, not Leslies, and VERY expensive.
    If anyone else has thoughts on this.....
    The Natural Chemistry Instant Pool Water Conditioner (which is the same as Leslie's Instant Conditioner) has been around for a while as "Instant Pool Water Conditioner" and is sodium cyanurate in a slurry. It dissolves quickly into water so is a fast way to increase CYA. It is, of course, more expensive to use than pure CYA so it's a cost/speed tradeoff. If you only need to raise your CYA a little, you can use Dichlor for a similar effect since it also dissolves quickly and you can use that as your chlorine source and build up CYA over time. For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
    May 2011
    Central AL
    Great, thanks for the replies ... that's why I figured it would be a good question to ask and hopefully let future searchers know as well. Unfortunately, other than Leslie's I do not have many other options. So it is either them or Big Box stores. Luckily, thanks to y'all I only have to buy CYA and Muriatic Acid at those places and WalMart for bleach, borax, and baking soda. I had to laugh today at WalMart I saw Arm&Hammer pool care products ... what a concept!
