Thread: My Numbers -
    May 2011
    Detroit, MI
    Default My Numbers -
    TC - 2.5PPM
    FC - 2.5PPM
    CC - 0
    PH - 7.5
    TA - 130
    Cal - 90PPM
    CYA Less than 30
    Pool Temp = 83
    Salt = 3200
    17500 gal Fiberglass 15X34 - I have a 1.5HP Pump with a Hayward EC40AC filter, a H-series heater, and a SWCG.
    I bumped up my SWCG time from 10% to 20%, that should up my FC.
    Since I have a fiberglas pool I think I read that Calcium doesn't matter... Is that correct?
    What is the salt supposed to be? I lost that manual...
    Waddya think? Should I be doing anything other than adding CYA...
    Default Re: My Numbers -
    Looks to me like CYA is the only thing you need to add, but you do need to find a source for the owner's manual because they will give the optimal amount of CYA to make your cell last as long as possible. It will also list the salt requirement for the SWCG model that you have. Otherise, it's looking good--how does your water look?
    May 2011
    Detroit, MI
    I'll find that manual and then adjust the CYA. I'll double check the salt too....
    Water looks great, and feels even better :-)
    Thanks for the feedback, I was wanting some confirmation that I was reading things correclty...
    John
    Sounds like you've got it under control
