Results 1 to 10 of 16
Thread: Please help me figure out my DE filter. I think the pool guy gave me bad info.
    SalemCastles Guest
    Default Re: Please help me figure out my DE filter. I think the pool guy gave me bad info.
    Have you tried running the filter at the "higher" pressure levels for any length of time? I'm wondering if the gauge could be faulty since your not getting the filtration performance at the lower DE levels. Have you checked the flow rate when the pressure is reading high? If your water circulation is good I'd leave it for a day and see what happens. Then I'd be looking for a new unit as it shouldn't be your problem to deal with since it's new. Just random thoughts from an old auto mechanic
    Jun 2011
    rochester hills, mi
    Quote Originally Posted by DurhamHouses View Post
    yes, once the filter gets passed the red line, i lose circulation. it got past the red line when using about 1/3 of the recommended DE
    Jun 2011
    Louisville KY
    A few duh questions.
    The inlets are not plugged?
    Your eyeball fitting is not clogged?
    The valve to the inlets is fully open?
    Jun 2011
    rochester hills, mi
    Well...a quick update.
    I got my chemicals balanced out and now my pool is ultra clean and clear and looking perfect.
    That being said, I'm still only using about 1/5 to 1/6 the recommended amount of DE.
    Just to clarify, I have no problem with the water flow in terms of inlets, eyeballs, valves, etc. Everything is functioning totally fine as long as the filter pressure stays in the good range. Once I add more DE and the pressure rises, then the flow stops to a crawl.
    Jun 2011
    Louisville KY
    Feels good to have a nice clean pool. Nice to hear a success story.
    I am still curious. Are you weighing the amount you are using?
    What's you PH level?
    Jun 2011
    rochester hills, mi
    I'll have to check the pH level...not sure. we had the pool water checked by a pool place last week and they had me set my salt chlorine generator to shock mode and said that after that we should be good and after doing that, the water cleared right up.
    I didn't weigh the amount of DE that's currently in there. There originally were about 6 scoops of DE in there. The scoops are small and each scoop weighs about 0.33lb so I have about 2 lbs in there. When I did that, the pressure was too high, so I bumped it, backwashed it, bumped it, backwashed it and after doing that, the pressure got down to normal. In other words I probably have at most 1 lb of DE in there if that.
    When I actually weighed out 6 lbs of DE, it was around 29 scoops. maybe my pool isn't filtering properly since there's not enough DE...i don't know... is there a way to know that?
    Jun 2011
    Louisville KY
    I ask about the PH because in the guide for the K-2006 test kit it says high PH level can lead to high pressure in the filter. How this works I don’t know but I glean that the PH level needs to be balanced.
    As for proper filtering, the pressure should be around 10psi and the flow from the inlets should be fairly strong. My shallow end inlet blows all the way across my 20 foot wide pool. With the pump running it is impossible to put a fitting on the inlet fitting. Not scientific but you get the idea.
    My gut feeling is the filter is clogged. I know you cleaned it already but I’d do it again. I know that filter is a bear to open with all those bolts but that’s all part of the pool game.
    I opened mine one year when it was acting up and I will never forget the glorious green algae covering all my tubes.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
