Thread: Above Ground pool vacs
    Jun 2011
    Default Re: Above Ground pool vacs
    Thanks for the reply and hello!
    I believe that the Polaris 65 is the same as the Superturtle right? Well one of the problems I was having was that the little filter that goes on the end of the hose was missing! I found it on the floor of the shed and reinstalled and it is working a little better now! The Turtle still does not clean the way I wish it would, it seems to stay in one spot and never seems to clean the back of the pool. This is a great concept as I have said, working off the return is just a great way to vacuum! So many things that can happen in the intake if you do not pay attention.
    Well as I have said I am going a different route, I am going with either the Rover Hybrid or the Rover Jr. I really cannot find out what separates the Jr from the Hybrid, but there is about a $100 difference so there must be something! I do like the fact that these are supposed to be programable and run off a 120v cord rather than messing with pool hoses! The Superturtle is the best vac I have used to date but for me still lacking that total clean I am looking for. I am hoping a Rover owner can pop in here and give me a little info on whether or not this thing actually works or not!
    May 2011
    Central AL
    I have not used either but in researching different ones, I found this ... I hope that helps
    Quoted from http://www.poolsupplyworld.com/pools...OOLROVERJR.htm
    "regarding the differences between the Aquabot Pool Rover Jr. and the Aquabot Pool Rover Hybrid.
    The Pool Rover Jr. is designed for above ground, flat bottom pools, while the Pool Rover Hybrid is designed for bowl-shaped above ground pools (with inclines up to 30 degrees), but can also be used with in-ground pools.
    The Hybrid cleans pools up to 40' in one hour, while the Pool Rover Jr. cleans pools up to 30' in 30 minutes. Both cleaners filter down to 2 microns, operate at 24V, have a 19 quart capacity filter bag and include a 40' non-corroding Kevlar power cable."
    18' Swim N Play Yukon Resin Hybrid AGP (7443 gallons)
    Waterway 19" Sand Filter (100#) and 1HP 2 speed pump
    Hayward AquaTrol-RJ salt water chlorine generator
    1 clear pool + 2 ecstatic little girls + 1 happy wife = 1 smiling dad
    Located in the insanely hot locale of central Alabama
    Jun 2011
    Quote Originally Posted by swimlane View Post
    Thanks for taking time to post this. I had a feeling that the Hybrid meant something like it could be used in an above ground pool aswell as an aboveground. I have a flat bottom 54" high Lomart ABG pool, I think the Rover JR will be fine and I think I am going to order it right now! I will be sure to post my review when I get the results! Thanks
  1. AG Pool vacs?
    By Watermom in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-16-2011, 07:09 PM
  2. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  3. Robotic Vacs for IG Pool- Good and Bad Experiences Please
    By myLABSpool in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-17-2010, 12:50 PM
  4. Hayward pool vacs and hose?
    By nthach in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-01-2010, 07:54 AM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
