Thread: pH Color Standard
    Scottsdale, Arizona
    Default pH Color Standard
    I've got the PS234S Test Kit and no pH color standard to match my pH test too... Anyone know where I can get one ?
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: pH Color Standard
    Yes, order a K-1000 test kit from Taylor Technoligies. It is the same as originally came in your PS-234s. If you don't need the reagents then just order the 1000 comparator block, part number 9781. I don't know if Taylor sells them individually (they sell a six pack) but you can find them on the internet. Here is one place that sell them. Here is another.
