Thread: pH Color Standard
    Scottsdale, Arizona
    Default pH Color Standard
    I've got the PS234S Test Kit and no pH color standard to match my pH test too... Anyone know where I can get one ?
    Default Re: pH Color Standard
    Yes, order a K-1000 test kit from Taylor Technoligies. It is the same as originally came in your PS-234s. If you don't need the reagents then just order the 1000 comparator block, part number 9781. I don't know if Taylor sells them individually (they sell a six pack) but you can find them on the internet. Here is one place that sell them. Here is another.
  1. standard, salt or nature2
    By gcurrlin in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2012, 02:33 PM
  2. Color Splash / Color Logic Replacement LED Ligths
    By shutitdown in forum Pool Equipment & Operations
    Last Post: 06-22-2012, 01:59 AM
  3. Is there a standard for pool return fittings?
    By stualden in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2009, 07:07 AM
  4. 2 Jandy Color Pool Lights/1 Color Spa Light not synced
    By dc in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 05:36 PM
  5. 2 Jandy Color Pool Lights/1 Color Spa Light
    By dc in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 12:19 AM
