Results 1 to 10 of 22
Thread: Just pulled cover off.. green swamp water
    Jun 2011
    Default Re: Just pulled cover off.. green swamp water
    If my stabilizer level was at 50, why is it important to not let the chlorine get below 3?
    Chlorine levels are based on CYA levels. If you haven't already done so, please take a look at the Best Guess Table in my signature below. If you drop below the necessary chlorine range, you risk an algae bloom.
    Jun 2011
    I looked at that before but didn't see why the ranges changed like they do. I guess algae is the answer. Does the cyanuric acid level decrease slowly with time?
