Results 1 to 3 of 3
Thread: kreepy
    Jun 2011
    ontario
    Default kreepy
    getting small amount of air only when kreepy is attached, running crystal clear with out have reattached all hoses without and air leaks. water level is 3\4 of the way up skimmer with no air in skimmer and all clamps have been check and tightened
    Default Re: kreepy
    Two possibilities:
    1. you have a leak you didn't notice in the Kreepy hoses where they are above the water. OR
    2. you have a leak in your suction piping or skimmer that only shows up when the Kreepy's presence increases negative pressure in the suction piping.
    I'd look at for problems in this order (from easy to hard)
    a) Kreepy hose leaks
    b) leaks at the pump around the lid or piping connection
    c) every where else.
    Remember, suction leaks let AIR IN, and do not show up as water leaking OUT.
    Ben
    Jun 2011
    ontario
    Default Re: kreepy
    thank you i will try
  1. Polaris vs Kreepy?
    By amkhoury in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-07-2011, 02:30 PM
  2. Kreepy Krawly
    By CanuckPool in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-18-2007, 11:01 AM
  3. Kreepy Krauly
    By jcarroca in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-13-2006, 03:17 PM
  4. Use the Kreepy Klear?
    By rifraf in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2006, 09:41 PM
  5. Our Kreepy won't work
    By torsie in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-21-2006, 01:38 PM
