Re: New Pool Owner, No Chlorine less than 24 hours after shocking.
When you added all that calhypo you hammered the algae and was the heavy lifting that cleared your pool. Reading this was painful as you seem a really capable person being badly mislead by all the misinformation being given you.
Your problem was caused by the pool guy and everyone saw as a chance to sell you stuff. You got "Pool-Stored" big-time. It has happened to all of us. Pool care is really simple but if everyone knew how simple it was the pool services would be out of business and half the pool stores with them.
Check out our sister site, poolsolutions.com and read the section on the BBB method. You will be amazed how simple it all is! It only gets complicated when the pool store has you put in a bunch of junk that makes it worse. Luckily Ben could walk you through it. From now on it will be so simple you will never use a pool service again and you wont believe how inviting your water looks.
