Thread: Question for the pool guru's about pipes/fittings etc..
    Default Re: Question for the pool guru's about pipes/fittings etc..
    #1 - Welcome to the Forum!
    #3 - they ought be universal, but the size is 1.5" - maybe you made a typo?
    #4 - you should match the new skimmer to the old one, the screw holes vary, even for the same sized skimmer. If you can, take the existing faceplate to the store when buying a new skimmer. (this isn't 'fool proof' but is a good start - the best way would be to find out the model number of the existing skimmer and order one that matches it)
    Ben's right: Flex isn't meant to be buried. Besides, hard PVC is very easy to work. I would also make sure no quick-connects are buried--that's a recipe for trouble. Glued fittings are best underground.
    Jun 2011
    NJ
    I went to the pool store and they had the fittings and ordered me a skimmer. I installed the fittings last night, I had to fab a plate to secure one of them as the metal is rotting away. I guess I'm going to just redo the 1.5" pipe with new PVC SCH-40. Is there any benefit to going to 2" or should I just stick with 1.5?
