Re: first post - aciam - converting pool from baquacil to chlorine
FYI. The procedure is in this PDF file (OXYplus™ is sodium percarbonate). The dosage was 5 pounds per 10,000 gallons (so 1 pound per 2000 gallons) which is less than the dosage normally recommended for ProTeam® System Support (but the purpose is different here) -- note that this is different than I wrote to Ben earlier since I found a reference to Orenda's instructions. Also, I thought that it was added without the acid and that after the conversion then acid was added to adjust pH as needed.
