You are FINE. But since you have an SWCG you should raise CYA levels to that recommended in the manual. Do not raise TA, and only raise CH if the manufacturer of the SWCG calls for it (Don't want to void the warranty). SWCGs seem to do better with lower TA levels and higher CYA levels.
