Thanks so much for your info.
I tested the water again this morning. I really love this Taylor test kit, thanks for the tip.
OK, yesterday evening when I tested it was getting a little dark, so I wanted to double check all my tests in good sunlight. Everything matches up except the CYA. I messed that one up, the CYA is most likely around 10 or so. When I get the tube to the 30 ppm mark, the dot fades significantly, but not completely. I can fill the tube all the way to the top before it disappears. Pool store tested it at 10 ppm, which is what I think is true. I know that I only have a few more tests left with this kit but I think I can get the CYA test solution at Wal Mart.
Here are this mornings #'s.
FC = .8 ppm
CC = .6 ppm (both using the .2 ppm method)
pH = 7.4
TA = 200-225 (using the 25 ppm method)
CH =300-325 (using the 25 ppm method)
CYA <30 (less than 30). Most likely around 10 ppm.
Water is looking much better, starting to get that "blue" tint to it again. Even lately when the water has been improved it has still had a green tint. Yesterday I scrubbed the walls and trouble places like corners and jets where the algae tends to cling. I also set my filter to run 2 hours during the night so that it doesn't sit so long without being turned over. I had it set to run from 9 am to 9 pm.
What I'm really interested in is has anybody ever come up with a solution to keep the sand level in the filter at the right level? Add some to the skimmer? Pop the top? I think if I marked the level in the filter using a really bright light I could keep tabs on it. When I had the filter apart I noticed that it allowed some light to pass through, so I was thinking that I could hold a Qbeam next to it at night to see if I could see the level. Kind of like when you stick a flashlight next to your hand at night and can see the red glow etc. I'll make sure not to melt the filter though, so don't worry about that, LOL.
