Re: Need some advice
That's the filter/pump that I have. You can use that as the filter and pump. It takes a type "B" filter. Like I said, you will have to clean that paper filter pretty regularly, but it will do the job just fine. It just requires a bit more work than the sand filter. I removed the filter cartridge and hooked into a sand filter and just use it as a pump. Some sand filters come with a pump built onto the unit, but I'm not sure what you have.
