Thread: My Pool’s Cement/Plaster Wall Has Caved In (Need Advice)
    Jun 2011
    Atlanta, GA
    Default My Pool’s Cement/Plaster Wall Has Caved In (Need Advice)
    I purchased a home 5 years ago with a 20 year old pool. The liner had just been replaced before closing.
    Over the years I pretty much became an expert in my pool’s maintenance. I replaced both the pump and sand filter myself, and could keep the water crystal clear.
    Last year a huge branch from a neighbor’s tree fell into our pool and damaged the lining. Our insurance company paid to have the lining repaired. Right after the repair another branch fell into our pool and punctured the lining again. This time it needed a new lining.
    Our insurance company this time would not pay for a new liner because of the previous claim. So we put the cover over the pool while fighting the insurance company and our neighbor’s insurance company. The neighbor’s insurance wouldn’t pay because it was considered an “Act of God”, and our claim was denied again.
    Then we were hit with a flood that caused part of our empty pool’s walls to collapse.
    Here is what our pool now looks like after a year of fighting with the insurance company:
    Our pool is in need of some serious work.
    I plan to repair the walls myself using 80 lb bags of Quikrete #1800 pool finish. I’ve heard that this product may have been discounted. If that’s the case, I read that I can use one bag vermiculite to one sack portland cement.
    After the walls are repaired I was wondering if there are other options to a vinyl liner? Could I resurface the walls with gunite?
    I’ve worked construction before so (I think) I have the skills to repair the pool myself, but I have some knowledge gaps that I need to fill before starting.
    Any advice is appreciated.
    Default Re: My Pool’s Cement/Plaster Wall Has Caved In (Need Advice)
    Way outside my experience range -- I've seen pools like that repaired badly. But I've not seen it done well, though I think it may be possible.
    Ben
  1. Pool cement crack isues
    By gibbyhome in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2012, 08:27 PM
  2. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 04:24 PM
  3. what kind of cement to use for stone coping and steel pool wall?
    By leon718 in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2012, 04:14 PM
  4. Ug pool- cement? -is a liner really necessary?
    By maclelld51 in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2011, 07:48 AM
  5. Cement vs Fiberglass Pool
    By jsack22 in forum In-Ground Pool Construction and Repair
    Last Post: 04-05-2011, 12:37 PM
