Thread: Pool Filter Running Time
    Jun 2011
    Connecticut
    Default Pool Filter Running Time
    I have done some research that says you should run ypour pool filter between 8-12 hrs a day, and most of the time during the daylight hours.
    However I have a pool timer and can set different on/off times. Should the pool filter be run for example 4 times a day for 2 hrs each time? or 2 times a day for 4 hrs each time, or once a day for 8 hours?
    Right Now I am running it @ 5 times a day for @ 2 hrs each time. I am not sure this is the best thing to do.
    Any body have any thoughts on this?
    Default Re: Pool Filter Running Time
    "Best" is what works for you, and your pool.
    You can find statements on the internet saying anything from "Run it just 4 hours" to "Run it all the time".
    In the Southwest, and in Southern Calif -- with DE filters and no thunderstorms and mostly inground pools -- 4 hours is common. In the Northeast , where above ground pools with undersized filters are common, running 24/7 is also common.
    What sort of pool, pump and filter do you have? How do you chlorinate? Where are you, and what sort of weather to you have?
    Ben
  1. Running Time/Intervals for Filter/Pump?
    By TheKs in forum Intex-type Pool Setup & Operations
    Last Post: 09-12-2012, 05:49 AM
  2. Running the filter while it is raining
    By majspool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 05:15 PM
  3. help Need to get my Filter Running
    By OldPoolNewOwner in forum In-Ground Pool Construction and Repair
    Last Post: 08-10-2006, 08:32 PM
  4. help! Filter not running
    By jabbajean in forum Pool Equipment & Operations
    Last Post: 08-04-2006, 09:38 PM
  5. New(to me) pool just filled filter running
    By svey72139 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 02:20 PM
