Results 1 to 10 of 20
Thread: Experiment: Homemade Sump Pump Filter to get rid of brown water
    Default Re: Experiment: Homemade Sump Pump Filter to get rid of brown water
    Heyyyy Marie!! (waving)
    Glad to see you back!!
    mbar's Avatar
    Ashland, PA
    Thanks, it's been crazy here, lots going on with family....The pool is now open, and today is sooo hot I am now going to go in it for the first time! I love that the forum is back to it's old self!!!
    Northeast PA
    And we love having you back! NOBODY gives better or more articulate directions on the step-by-step process to clear out metals!
    Good to see you, Marie!
    Jun 2011
    New Hampshire
    Ok, got it regarding the use of bleach! Same as Chlorine but more dilute and cheaper
    Our Chlorine levels from the initial shock I did were right where they should be as of last Saturday (have not tested since because I don't want to add anything until the water starts to clear up). Hoping the viz is a little better when I get home tonight!
    So I should not be adding anything at this point, right? Just let it filter for a bit and then retest and see where we're at?
    Gosh I hope this works. It's going to be 98 tomorrow. I know having it ready for tomorrow won't happen, but it sure is heating up FAST here so the sooner the better!
    Thanks again!
    Jun 2011
    New Hampshire
    Cool Re: Experiment: Homemade Sump Pump Filter to get rid of brown water
    38 hours into using our makeshift pump and I can actually see the bottom of the pool! It's still pretty brown but not nearly so opaque! I nearly squealed with delight this morning! Progress!
    Bravo! Keep it up!
    Jun 2011
    New Hampshire
    Wink Re: Experiment: Homemade Sump Pump Filter to get rid of brown water
    Just a quick update in case anyone else out there is starring at their dark brown opaque pool ready to cry... there is hope.
    Our filter has been running for three days (lost several hours yesterday due to Tstorms, however!) and this evening I am happy to say that we have gone from dark brown completely opaque water to light iced tea which is completely and 100% transparent. We can see clear to the bottom and across the pool.
    Amazing. A homemade contraption, no chemicals, and my water WILL be free of metals!
    Just to be clear - we have HORRIBLE water and a cheap crappy intex pump that came with the pool and other than some shock and some clarifier from Walmart have not treated the water. The clearing is 100% thanks to this homemade pump! No sequestrants, no iron out, nothing.
    Next I need to start looking into getting rid of the brown staining. Hoping we will be swimming by Sunday.... This forum is awesome! I never would have gotten this from the pool store!
