Results 1 to 9 of 9
Thread: HTH Algae Guard- Anybody use it?
    Default Re: HTH Algae Guard- Anybody use it?
    The chlorine/CYA relationship has been known definitively since at least 1974 as described in this scientific peer-reviewed paper. For more info, I suggest you take a look at the "Chlorine/CYA Relationship" section of this post, look at this thread in The China Shop, and this post on why the FC/CYA ratio is a decent proxy proportional to the hypochlorous acid concentration.
    In simplest terms, there is a race between algae growth that is accelerated by nutrient levels (phosphates and nitrates being most limiting), sunlight and temperature and is decelerated by hypochlorous acid and any algaecides that may be present. Regardless of algae nutrient levels, the growth is ultimately limited by sunlight and temperature so there is a hypochlorous acid level that will kill algae faster than it can reproduce without the need for any algaecide. The problem is that the hypochlorous acid level is not just dependent on the Free Chlorine (FC) level and pH, but also on the Cyanuric Acid (CYA) level since most of the chlorine is bound to CYA in a series of compounds called chlorinated isocyanurates that are not strong oxidizers nor disinfectants (i.e. they don't kill algae). So it is critically important to maintain a high enough FC/CYA ratio to be able to kill algae faster than it can reproduce. If you maintain that ratio, then you won't get algae and won't need any supplemental algaecides or phosphate removers to prevent such growth. Ben Powell was first to create the Best Guess Chlorine Chart based on scientific principles and his own experience.
    In my own pool through most of my pool ownership I have prevented algae growth using only 12.5% chlorinating liquid with no algaecide, phosphate removers, clarifiers, flocculants or weekly shocking. It costs me around $15 per month for my 16,000 gallon pool, but I have a mostly opaque pool cover that keeps my chlorine usage to around 1 ppm FC per day even though the pool is used every day for 1-2 hours. A similar story (with somewhat higher chlorine demand) is true for literally tens of thousands of pool owners on this and other related websites.
    Jun 2011
    Ok attempting to reask my question better since I didn't really get my question answered...
    Is there anybody using HTH Algae Guard (3x conc.) in their pool and what has been your experience with it when using it?
    May 2011
    Quote Originally Posted by 3d-aholic View Post
    Yes, I used it when I opened up my pool this year. Bad idea. My pool foamed like crazy. It wasn't until I got the chlorine levels up high enough (using bleach) that my algae problem was solved...(thanks to advice I received in this forum, btw!)
    Apr 2011
    virginia
    I've heard of it, seen it, never used it personally...
    It's ammonia based, which means it "eats" chlorine, increasing chlorine demand with no sanitizing/oxidation effects since all the chlorine is used to breakdown the ammonia, then the chloramines...
    In practice, all ammonia based algaecides do this, as well as increasing the opportunity for foaming, greasy films, and follow on algae blooms as people who don't understand what happens to the chlorine fail to get the chlorine levels back to an acceptable level. They add 1lb, or 1 gal, or 3 pucks, because that's what it always takes, and fail to realize how fast that chlorine is absorbed in the ammonia battle without helping the pool- then they think the chlorine is at fault!
    I think chem-geek had a post about the amount of chlorine needed to get rid of ammonia- and it is large amounts!
    Meaning you have to add that much chlorine, plus enough extra to sanitize/oxidize the algae in the pool!
    Unless Arch Chemical changed their products after buying Applied Biochemists (who did sell Polyquat under several of their brands) they currently only sell copper and linear quat based algaecides in both their HTH and PoolLIfe brands. (I guess they did not want to pay royalties to Buckman Labs since they stopped selling polqyat around 2006.) A few years ago when I was still selling HTH the 60% algaecide was a linear quat and therefore not recommended. Linear quats foam like crazy, sting the eyes, and break down quickly in the presence of chlorine. I assume it is still the same formulation but I have not seen a bottle of it to read the ingredients to see if they have changed but they were (are) :
    Alkyl dimethyl benzyl ammonium chloride, 30%
    Alkyl ethylbenzyl ammonium chloride, 30%
    The remaining parts are inert ingredients, 40%
    It seems that Arch Chemical is now following Chemtura's lead in making their MSDS unavailable online.
    Hope this answers your question.
