Thread: New house, new pool, 10years old, need help!
    Jun 2011
    eastern pa
    Default New house, new pool, 10years old, need help!
    Hi all! I just purchased a 10 year home in eastern PA, Reading area, and it has an in ground pool, salt water system, liner, etc. My problem is , it's a pump/filter system that so far, any company I've had has been unfamiliar with. I know may people with in-ground pools, and they have the typical set up, with the filter/ pump off to the side behind some landscaping, etc. Mine is different, it has a pump which is in a pit/well in the concrete off the deep end of the pool. It also has what looks like 2 round filter/skimmer areas in the same area. All of this in covered with a vinyl cover that sits flush to the concrete. Anybody have any idea on how to work on or get parts for this type of system? I've had no success so far with local companies, and it's 100 degrees today and I don't have a pool!
    Thanks,
    Joel
    Default Re: New house, new pool, 10years old, need help!
    Before anyone can help, you'll really need to send in some photos, to poolforum AT gmail DOT com.
    Send them in as large size as you can; I'll reduce them as need.
    Ben
