Results 1 to 8 of 8
Thread: Timer recommendations
    May 2011
    Rhode Island
    Default Re: Timer recommendations
    Thanks. The GE/Home Depot model may be closer to my needs.
    By "wet location", I didn't mean it would be sprayed or anything. But if I turn off the pump to clean the basket and turn it back on, chances are my hands will be wet.
    My father (in Europe) has a timer that's in a waterproof enclosure. You have to open it to program it, but there's a switch on the housing to control it manually. I think it's an ON-OFF-PROGRAM type switch (if I remember properly). That's what I was looking for.
    But if that's not an option, I was wondering what people with a timer did when they need to turn off a running filter (for cleaning basket, etc.) or turn it on during "off hours" (for vacuuming, etc.).
    Glenn, I assume your timer stops when you turn off the switch and you have to reset the clock now and then.
    Largo, Florida
    Since you already have a switch, you could use something like this perhaps: http://www.google.com/products/catal...ed=0CFcQ8wIwAQ
    SalemCastles Guest
    I use the rocker switch inside the timer mostly ... it is three position, On - Off - Timer ...but yes if I turn it off with normal switch I would have to reset the time.
