Results 1 to 10 of 33
Thread: Pool walls out of square
    Jun 2011
    Louisville KY
    Default Re: Pool walls out of square
    It is hard for anyone not in the game there in CA to know what’s fair. The man hours @ $15/h seems very fair to me, in fact it seems ridiculously low. The other charges are harder to gage because they include a lot of mysterious cost like equipment and horse feed
    Sadly with just about any contractor you almost have to be there 24/7 and baby sit the whole project.
    I’ve had my share of battles with them, won a few lost a few.
    Have you looked at your contract for any kind of quality clause or acceptable tolerance gibberish?
    Know any lawyers? Have you considered other bids from the competition?
    From the pictures it appears that the construction is far from complete. I’m wondering why it’s so complicated to square it at this stage?
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    We went with this company because it is suppose to be the best company in our area, and we wanted quality, which is not the case now i guess.
    They also feel that they can remove the walls with out damaging but I can't see how. The concrete around the angles will be quite hard to jack hammer out with out damaging the supports.
    We had lines for them to measure off of and they were all squared, they didnt use any of them and theres no way to square the house around it, since the pool is 7" out of square. We moved the house lines to line up with the pool wall but no matter how you turn the house the pool will always be out of square with the other 2 walls. Its a parallelogram no way to put that in a square room.
    The pool company insisted that they had to put the pool in first, now either its going to be out square or the pool comes out.
    Another thing I was just thinking after reading some other posts, should there be a floor drain in the 7' deep end, that should of been put in when the floor was poured
    Jun 2011
    Louisville KY
    Quote Originally Posted by Figstimpy View Post
    It's not a drain per se but a feed line to the pump. I don't suppose one is absolutely necessary, though I've never seen a pool without one. Can’t see it in the pictures.
    Did they lay the plumbing?
    Let them worry about damage to correct the geometry. All you want is what you paid for – a square pool. Any damage they do in the fix is their problem.
    There was no plumbing laid, and the floor is solid no holes or drains
    Jun 2011
    Louisville KY
    Then check the plans. If there’s a “drain” they messed up.
    The plans might have a piping diagram too, a single line drawing showing the piping valves, pump, filter and any other required equipment.
    If you need help reading the diagram post a picture.
    No plans other than the pool drawing, but here is the list of stuff from their quote
    THANK YOU FOR THE OPPORTUNITY TO QUOTE THE LORENTZ FAMILY
    YOUR INSTALLED DELUXE 14X28 IN GROUND POOL INCLUDES:
    EXCAVATION OF POOL
    42” 14 GUAGE STEEL WALLS & SUPPORT STRUCTURE
    GROUT CUSTOM FLOOR
    CONCRETE SURROUND FOUNTATION FOOTING
    40 TONNE ¾” WASHED STONE BACKFILL TO SUPPORT PLUMBING
    HAYWARD RECIRCULATION KIT- SKIMMER & 2 JETS
    PLUMBING DONE IN CSA PIPE, FITTINGS, UNIONS AND VALVES
    COPING-ALUMINUM IN WHITE
    LINER- FULL PRINT IN 30 ML
    LINER PADDING AND LINER COPING LOCK
    HAYWARD PUMP 1 HP SUPER PUMP & SYSTEM 3 CARTRIDGE FILTRATION
    STAIR- 8 FT. WALK IN ROMAN STAIR IN WHITE- CENTER SHALLOW END
    HEAT SAVR SYSTEM-LIQUID SOLAR BLANKET WITH AUTOMATIC METERING PUMP
    LIGHTS BY AQUALAMP – 2- RAINBOW COLOURED WALL LIGHTS 12 VOLT
    IONIZER BY CHLORINE SAVER FOR THE WEEKLY WATER TREATMENT
    HAYWARD CHLORINATOR TO SUPPORT IONIZER
    TYPHOON SLIDE WITH WATER CONNECTION
    BRASS DECK ANCHOR FOR FUTURE BASKETBALL GAME
    MANUAL MAINTENANCE EQUIPMENT-EVERYTHING TO CLEAN AND TEST THE WATER
    START UP WATER TREATMENT KIT & WATER BALANCING
    DELUXE POOL PRICE QUOTE AS LISTED ABOVE
    14X28 RECTANGLE W/ 2 FT. RADIUS CORNERS $31,796.+ 4133.(HST)=$35929.00
    Page 1
    Untitled
    THE REVOLUTION POOL LIFT WITH WHEELCHAIR INCLUDED
    ADDITIONAL BATTERY 24V $11,486. + 1493. (HST)=$12979.00
    OR
    THE LIBERTY LIFT WITH WHEELCHAIR INCLUDED
    ADDITIONAL BATTERY 24V $11719. + 1523. (HST)=$13242.00
    CONSTRUCTION TERMS: ALL SUBJECT TO SITE INSPECTION
    -EXTRA STONE AT COST OF STONE, PLACEMENT N/C UPTO 60 TONNE
    -ELECTRICAL BONDING, WIRING, BUILDING PERMITS, LOCATES AND WATER SUPPLIED BY OWNER.
    PAYMENT TERMS:
    PRE SEASON BOOKING (NOV.-APR 2011) $1000. REFUNDABLE
    35% UPON AGREEMENT OF CONTRACT LESS PRE SEASON DEPOSIT
    25% UPON COMPLETION OF WALLS
    25% UPON COMPLETION OF LINER
    10% UPON COMPLETION OF POOL
    5% 30 DAYS AFTER COMPLETION OF POOL
    TO BE DISCUSSED:
    FLOOR PLAN OF POOL, LINER PATTERN
    TIMING FOR POOL AND BUILDING CONSTRUCTION
    IN FLOOR HEATING RE SLIDE AND LIFT MOUNTING HARDWARE IN DECK
    DECK INSTALLATION AROUND POOL FIXTURES
    LOCATION OF EQUIPMENT ROOM
    HEATING POOL WATER, ROOM AND CONTROLLING HUMIDITY OF ROOM
    PLUMBING REQUIRED TO CONNECT POOL TO HEAT SOURCE
    RUBAROC FLOOR COVERING START AT $12. PER SQ. FT.
    Page 2
    Untitled
    THIS IS A STARTING POINT FOR PLANNING YOUR INDOOR PROJECT. IF YOU HAVE ANY SPECIAL
    REQUEST OR WANT TO MODIFY THE DELUXE KIT, JUST CALL FOR PRICING.
    the size was adjusted to a full L and to 48" walls
    heres the diagram
    thanks
    Jun 2011
    Louisville KY
    Hmm the quote doesn’t specifically list a drain.
    It does say HAYWARD RECIRCULATION KIT- SKIMMER & 2 JETS
    That would imply the filter is fed from a skimmer only and the water returned to the pool via the 2 jets. That saves some plumbing I guess.
    The interesting thing I see is the Installation Data that lists the point to point dimensions. I suppose that’s how the problem was discovered.
    You can argue it’s their error they are responsible to meet the specs. I guess you have to fight it out with them.
    Good luck Mr. Lorentz.
