How is this not in every pool in America with a price tag of ONLY $59.95!!! No electricity needed, no replacement parts...
**Plz no red, I realize this is going to do as much as clipping a potato chip bag clip onto my PVC pipes.**
http://www.poolmart.com/magnetizer.asp
A simple and effective patented magnetic water conditioner is now available for your pool. Laboratory tests prove that by simply strapping the Magnetizer on the return line to your pool, the Magnetizer reduces sanitizing chemical usage by 30% to 50% while stabilizing pH and eliminating all pH chemicals, thereby saving you money. The Magnetizer helps to eliminate algae, keep water clean and improve the clarity of your pool.
How does it work?
As water molecules pass through the powerful and highly focused magnetic field, the Magnetizer Pool System does two things: Polarizes (organizes) molecules and gives water a net positive (+) charge. This physically restructures the water making it provide all the great benefits described below.
How it Works
Magnetizer Conditioning
Magnetized water produces the benefits of soft water. It also magnetically locks the chemicals into the water resulting in:
Reduced chemical eye and skin irritation
Reduced obnoxious chemical odours
Luxurious silky feeling
Reduced Chemical Costs
Bromine, chlorine and other chemicals used in your pool maintenance mix more completely and effectively in magnetized water. The reduced surface tension and the increased ionic activity of the magnetized water helps to reduce operating costs as well as reducing chemical needs.
Stabilized pH
pH is the balance between charges in the water. Wide variations in pH will damage equipment while frequently reducing the effectiveness of the chemicals. By magnetically organizing the water molecules, the wide range of the pH swing is reduced, as is the need for chemical usage.
Improved Filter Performance
The positive water charge pulls skin oils and tanning lotions into the water allowing them to be removed by the filter. The result is a pool that is almost self-cleaning.
Remove Scale
The Magnetizer Pool System puts a positive charge into the water. This not only stops scale build-up, but dissolves pre-existing scale deposits. This scale removal protects equipment and allows heaters to operate at peak efficiency, thereby reducing energy dollars.
