Results 1 to 10 of 11
Thread: Leveling land with a roto tiller for a 14 ft pool.
    May 2010
    Default Re: Leveling land with a roto tiller for a 14 ft pool.
    Here is a quick, cheap and easy way to think about. Go down to you favorite Lumber yard and buy a 8 foot long 2x4 that is good and straight. Drill a small hole approxinately 1 inch from one of the ends and insert a long screw or nail into the hole so it protrudes through the other side. Stick the Nail into the ground at the approximate center of your pool, and then all you have to do is put a carpenter's level on the 2x4 and spin the 2x4 like the hands of a clock around the "axis" and check level. You will see if there are gaps under the 2x4 and you will be able to see where you are high and low. Finally, in my area, the roughed in dirt pool area is covered with a layer of sand, and the 2x4 comes in real handy to "skreet" the sand flat, level and smooth.
    The 8 foot 2x4 should give you a good 16 feet of "level" ground for yor 14 foot pool.
    Hope this helps
    Clever! And this from a guy who looks like Harpo Marx making a "Gookie"!
    May 2010
    Gee Carl, I'm truly touched! You can learn alot from a BIGTALLDUMBGUY!
    LOL!
    Honk! Honk!
    (what else can I say?)
    Jun 2011
    Louisville KY
    Quote Originally Posted by BigTallDumbGuy View Post
    Hope this helps
    This is a great post. Thanks.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    May 2010
    No, I did not know that Harpo was a little guy, but I am sure he was extremely smart and he was very talented. I put his picture up to inspire me to not be such a BIGTALLDUMBGUY, but it only works some of the time. The key thing is, with a name like BIGTALLDUMBGUY, nobody expects too much. So maybe I am not so dumb after all.
    Ah, you won't get away with that! Everybody expects you to be to reach stuff on the top shelf and change light bulbs without a ladder!
    As a kid Harpo used to watch a cigar roller named Gookie who would puff out his cheeks and stick out his tongue as he rolled the cigars. Naturally Harpo immortalized Gookie in your avatar!
