Re: Is Old Liquid Conditioner Ok to Use?
If it's supposed to be a liquid, and now it's a paste, I wouldn't use it in the pool. However, depending on the volume of your pool, if draining/refilling is easy for you, then I guess you could try it and just drain if it doesn't work or really messes up your water....your call, but I personally wouldn't use it.
