Yeah, something seems to be set up wrong.
I wish I could figure out what is set up wrong. The vacuum hose is new and it did the same thing with the old hose. All gate and ball valves are fully open. The pump strainer basket is clear of any debris.
What pump model did you have and what do you have now?
Mark
Current:
The pump/motor have the following info:
EcoKleer
Waterway pump 1.5hp
Model #SD 1007137411
Motor 1081/1795 pump duty
Century Pool Part 0-177894-24
Old:
There is only 1 label on it but imprinted on it is Waterway Hi Flo
Century Pool/Jetted Tub Motor 2hp
1081/1795 pump duty
part number 7-177894-24
