Thread: Chlorine Problem
    Mar 2011
    San Diego, Ca.
    Default Chlorine Problem
    Hello All! New to the forum and this is my first post. I have a pool that will not hold chlorine! Everything else I test is ok, but the chlorine. Any suggestions?
    Default Re: Chlorine Problem
    Welcome to the forum! If you can give us a little more information, someone here can try and help. What type of pool is this and what is the volume? What type of filter and what size of pump? We also need a complete set of current water testing results taken with a drops-based kit. Tell us exactly what all you have added to the pool, meaning ingredients -- not just "shock." Lastly, tell us what your CYA reading was when you closed the pool in the fall. Thanks!
  1. chlorine ph problem
    By c2d1700 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-14-2012, 12:26 AM
  2. chlorine/algae problem
    By kaufmh in forum Dealing with Algae & Slime
    Last Post: 06-10-2011, 02:14 PM
  3. Just getting started and have a chlorine demand problem
    By bjoy1956 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2011, 06:19 PM
  4. chlormatic III chlorine generation problem
    By cobia in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-10-2007, 11:35 PM
  5. Free Chlorine problem
    By Seadog in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-20-2006, 05:55 PM
