It did not bubble with just vinegar. After putting baking soda on it, it did not wipe off. With my nails I can scrap it off after putting those two on it. It feels and looks like dried sand.
Welcome to the Forum!
From your description, it sure sounds like calcium (with a little algae for the green). Calcium should react to acid and fizz (like Ben said).
I've got a thought, but I'm not sure it would be safe for the liner, so I'm leery of mentioning it. Replacing the liner would take this issue out of the picture, but I don't know if your finances allow for that. If they do, you can try what I'm thinking of and, if it wrecks the liner, you were ready to get one anyway.
I'm sorry that this post is pretty much 'non helpful'
We are hoping we can get one more year from this liner. Thinking a stiffer brush would maybe take it off after using the vinegar and soda. I put vinegar on then rubbed soda on it. Is there a better way to apply the two?
If you can scrape a bit off, and put it in a glass with vinegar overnight, that would tell us whether it's calcium carbonate based -- it will dissolve overnight if it is. I'm pretty sure I know what it is, but can you go ahead and send me some pictures? (Send to poolforum AT gmail DOT com)
If it's what I think, you can go ahead and refill, and start your pool. I can help you get rid of it over the next few weeks, without damaging your pool. You do NOT want to use a heavy brush, or acid, on a vinyl liner.
Ben
My husband tried to flake some off, it doesn't come off in large flakes, large granules of sand like stuff. will get pics tomorrow of the pool.
Now, some info that my husband just told me......
--pH is always way high, never seems to be able to get it below 7.6. I know we go through a lot of ph minus.
--Using test strips that came with the saltwater system, the TA is gray, which is not on the strip. He is assuming his TA is way high
Also, we are in the country and use well water, if that is any help.
I thought about cleaning the rest of the bottom and refilling it tomorrow evening and start new.
Is there a step by step guide on how to start your pool up and get it going the right way, without using all the unneeded chemicals?
We do have a saltwater system, just got this year. We use water softener pellets for the salt.
I want to thank all for the help. Truly appreciated. Any questions, just ask.
small granules are fine -- just put some in a clear glass and add vinegar, and leave it overnight. We really need to establish what the granules are, b4 you refill.
It would be a good idea to seal the glass with Saran-type wrap.
It did not dissolve in the vinegar.
And I had already went to bed so did not get the message to cover it.
