Thread: stained vinyl liner
    Jun 2011
    Default stained vinyl liner
    Opened my above ground pool, algae on sides and bottom. Brushed and vacuumed debris after adding startup doses of chlorine and algaecide. Algae appears to be gone, but the liner is stained brown specifically on the side walls, less on the bottom. Water tested balanced by my pool store. How do I remove the stains?
    Default Re: stained vinyl liner
    Depending on what caused the stains, a good shock probably will get rid of them (meaning attain shock level and hold it there for a few days to see if it makes a difference). Do you have metals in the water? Does the stain end where the waterline is?
    It's really hard to answer the question without a good set of water test results...
  1. Light Brown stained vinyl liner everywhere but under wedding cake pool steps
    By kelhoda in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-30-2013, 02:41 PM
  2. Pool Not Opened in 2 Years - Vinyl Liner Stained & Sagging
    By zooba72 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-29-2012, 03:28 PM
  3. Stained Vinyl Liner
    By Cpagasky in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2011, 08:37 AM
  4. Pool is clear finally, Now the liner is stained.
    By Lawrosa in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-20-2011, 10:46 AM
