Re: Pump recommendation
2 or 2.5 sounds HUGE if you don't have a spa. Perhaps it's oversized to be able to run the Polaris simultaneously?
Check the HP and the service factor on the pump and post back here. If you get good results now, you will likely want a similar sized pump, just ideally one that's more efficient and quieter.
23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
