Thread: Ascorbic Acid - stain removal
    Default Re: Ascorbic Acid - stain removal
    I would bump up the chlorine a little bit, it's entirely possible that you've got an algae bloom trying to happen. I know you can't go all the way up to shock level for now, but I would at least aim for 3-5 ppm for now. Keep the filter running, and see if that helps.
    mbar's Avatar
    Ashland, PA
    When you get the chlorine to hold, and if the water is still cloudy, let us know. It happens to me when there is a lot of staining and I do the treatment. When this happens I sometimes use a flocculant. I hate to use any chemicals that I don't have to, but sometimes it speeds up the process.
    Northeast PA
    I see that Mbar and I were typing at the same time yesterday--definitely follow her advice--she's the expert on metals around here, besides Ben!!
    Great to see you back, Marie.....
    mbar's Avatar
    Ashland, PA
    Thanks Janet, I am trying to keep up with the metals forum to see if I can help. I don't have the chemistry background, but I do have lots of experience, since I have had my white fiberglass pool for 12 years, and live in the middle of the woods with a well for my water - makes it very interesting!
    Northeast PA
    Hi, Marie! I'm glad to see you back around here and we ALWAYS appreciate the help you give. As one who has actually seen Marie's pool, I can attest to the fact that she knows what she is talking about. Her pool is perfect and nestled into a beautiful backyard!
    Lisa
