Thread: Intel 5000 Pool
    Digger is offline Subscriber Thread Analyst Digger 0
    May 2010
    Milton, PA
    Default Re: Intel 5000 Pool
    LOL! No they are not Amish, or anything like that. I guess they just haven't found a use for it. Okay, thanks for you help, I just got a call from him, and I said I didn't want to be pushy, if he wasn't ready to make the big change, thats fine, I just wanted to help them. They have done so much for us! Anyhow,he is going to continue doing what he is doing for now, So Thanks so much for help! I need to focus on my own beautiful hole in the ground, and keep that sparkling, LOL!
    BigDave's Avatar
    Well, since you friend is blindly dumping chems in the pool, I'll bet you get another chance to help.
    Be well.
    Hi Digger, and welcome back!!
    We absolutely have no problem with you asking for advice with your friend's pool, maybe after they discover how good it can look they'll be more inclined to join us themselves!!
    I don't know the gallonage of that pool, but if you can give us length, width, and water depth, we can figure it out. If indeed it is 5000 gallons, then each quart of 6% bleach will raise the chlorine by 3 ppm. Assuming the water is still clear, they will need to keep the chlorine between 3-6 ppm until they can get stabilizer in the water. Until the stabilizer is there, the sun will eat up the chlorine very quickly, so they're going to have to add bleach 2-3 times a day to keep it from going below 3 ppm. They can go ahead and add stabilizer to the pool, either through the skimmer if there is one, or by hanging it in a sock in front of a return. Target about 30 ppm CYA, for now. Once that's done, I would go ahead and run another set of tests on pH and alk, just to see what needs to be done about them.
