Thread: Replacing eyeball returns
    Jun 2011
    Default Replacing eyeball returns
    My pool has flush mount eyeball returns that I would like to replace with a different type that makes it easier to adjust. The retaining ring that holds the eyeball in place has two nubs on it and these have deteriated over time so they cannot be adjusted. I have yet to find a wrench that fits these. My question is how do I remove these? From all of the pictures I have seen there is a nut like structure on the back end that is wider than the head. The pool plaster is around the head section and it looks like if I try to remove it, it will damage the plaster. What are my options?
    Honesdale PA
    Default Re: Replacing eyeball returns
    Welcome to the forum.
    Bumping this thread to the top of the list. Any ideas anyone?
  1. Return eyeball has a funnel
    By Bonnie25 in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 09:01 PM
  2. Aiming the eyeball
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-22-2012, 11:26 PM
  3. go pens- eyeball angle
    By go pens in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-05-2011, 12:40 AM
  4. Eyeball direction?
    By abessellieu in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 01:54 PM
  5. Eyeball looks where?
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 05-20-2006, 09:15 AM
